Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
PROBLEM HELP fitting datsun 1200 ute with a 120y brake booster?
Demo
Posted on: 2007/7/17 5:53
How do you guys fit these ???
Do i need to remove the studs and put longer 1s and if so do they come out??? or do i space out between fire wall and brake booster spacer plate??? or bolt up normaly and shorten rod and cut hole bigger??? or none of the above??? any help of some1 that has done the conversion before will be appreciated any help as i want to hook up asap Thanks again every1 so far
#2
Re: PROBLEM HELP fitting datsun 1200 ute with a 120y brake booster?
Tyrie
Posted on: 2007/7/17 7:44
most that I've seen have had a shortened rod
