#1 need A12A connecting rods
kakimotoz Posted on: 2008/1/5 2:38
I am in need of some A12A connecting rods if anyone knows of where i can get them i would appreciate it thanks
#2 Re: need A12A connecting rods
ddgonzal Posted on: 2008/1/5 5:01
Have you tried Nissan? Part number 12100-H8500. They are listed in the latest catalog (meaning they *might* still be available).
#3 Re: need A12A connecting rods
kakimotoz Posted on: 2008/1/5 22:59
yea i checked and the people i called said no but if you could check in a dealer near you and see what they say i would appreciate it
#4 Re: need A12A connecting rods
ddgonzal Posted on: 2008/1/5 23:02
All the dealers across the USA have access to the entire inventory. So it won't help to check another.
Unless you didn't have the part number. Sometimes they won't bother to look it up. If you didn't give them the part number, call another dealer and ask.
#5 Re: need A12A connecting rods
GreaseMonky Posted on: 2008/1/6 3:47
Are they different from a A12 if not i have a set
#6 Re: need A12A connecting rods
Dodgeman Posted on: 2008/1/6 4:31
Yes, they are different.
The A12A uses a 75mm bore size & these pistons use the larger pin in common with the A14 & A15 models, The A12A is based on the short deck block, so the rod is the same length as the 1200 & A12 models, but with more 'meat' at the little end & a bigger pin hole.
This rod has the same dimensions as the short stroke A13 engine which differs only with its 76mm bore.
