Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
[VIC] - FOR SALE - 1972 Datsun Sunny 1200 GX KB110 2D Coupe, 5 SPD MAN, A15 1.5L ENGINE
ruredi
Posted on: 2011/11/15 6:22
1972 Datsun 1200 KB110 2 Door Coupe
Original 81,226 Miles (130,720 Kilometers). I bought this car off a 61 year old bloke in the country town of sale. I had full intentions on keeping it forever but unfortunately something major has come up in the family and this has to be the first to go. An extremely regretful sale. Car is unique in every way and you will not find another like it again for a very long time. Everything has been done properly. Previous owner used to build engines for Bathurst cars back in the day and had a lot of attention to detail. Car has to be seen in person and driven to fully appreciate it. Not much left to do...interior could use a work over. Other than that, nearly everything is perfect. The car was Roadworthied on 28/10/11 and needing nothing. I believe if the new buyer purchases before 28/11/11, they should NOT require another RWC. Car is registered until 02/04/12. I serviced the car on the same day as the RWC including all new premium oils and filters. Car starts first time, every time and is a ball to drive. Engine is very high revving and the performance is impressive for such a small engine. Car is located in Melton West (3337). Please call on 0421-158-036 if you have any questions. Engine Rebuilt A15 including new rings, bearings, welsh plugs, water pump and all new gaskets. Engine balanced and bored 1mm with matching flat top pistons. Modified oval port head including resurfacing, valves lapped and valve stem seals replaced. Standard valve springs. GX Twin Carbs including GENUINE GX TWIN CHOKE CABLE (WORTH A PRETTY PENNY) Cam Specs -.326 Inlet .326 Exhaust . Exhaust opens at 77 degrees and closes at 42 degrees Inlet opens at 42 degrees closes at 77 degrees. Exhaust duration is 243 degrees. Inlet duration is 243 degrees. Inlet lobe lift @ TDC on the overlap .106 degrees. Compression ratio is approx 10 to 1 plus. Transmission A60 Series 5 Speed (Typical 5 Speed pattern...NOT DOG LEG). Clutch & Flywheel Standard. Suspension Front - 1984 TRX Bluebird shortened struts with Camira inserts (1 deg Negative Camber), Rebuilt front end. Rear - Standard Leaf Springs, Heavy Duty Shockers. Brakes FRONT & REAR '84 TRX Bluebird Discs and Callipers. '84 TRX Bluebird Master Cylinder and Datsun 120Y Brake Booster. Diff Datsun 1200 Ute Housing with '84 TRX Bluebird center 3.89 Gear Ratio. Other 14” Alloys. GENUINE ORIGINAL GX BONNET (Any Datsun enthusiast knows what these are worth), GX Stripes and GX Analogue Clock. Please no time wasters, test pilots or ridiculous offers. OFFERS ABOVE $8,000 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#2
Re: [VIC] - FOR SALE - 1972 Datsun Sunny 1200 GX KB110 2D Coupe, 5 SPD MAN, A15 1.5L ENGINE
ruredi
Posted on: 2011/11/17 5:05
THANK THE GODS THE CRISIS HAS BEEN AVERTED!!! NO LONGER NEED TO SELL SO NO LONGER FOR SALE!!!
I have been dying a slow death teh last couple of days thinking about the idea of this leaving my garage!
#3
noteven
Posted on: 2011/11/17 5:33
Thank god!
Would of gladly bought it, stored/wanked over it then sold it back
#4
Dion120Y
Posted on: 2011/11/17 12:20
want to buy my injection?
#5
ruredi
Posted on: 2011/11/17 12:39
I thought you sold that to your mate?
#6
nt1200
Posted on: 2011/11/17 12:50
hahaha your unreal nath but i must say i wouldn't mind mine looking like that! You can view topic.
