#1 Fuel Sendor Connections
Sumith Posted on: 2011/12/1 6:37
Hi Guys
i see there are 3 connections to the Fuel Sendor at the tank like these are what are these 3 about ? i got only 1 connection on my b210 , the removed wire is the dash gauge sender which i cleaned it and fixed it is working fine now,what are the others ? i got a Fuel indicator bulb at dash gauge one would be for it ? then the other connector ?
thanks
regards
sumith
jpg  Fuel sendor.JPG (65.76 KB)
10994_4ed7208f3a224.jpg 640X480 px
#2 Re: Fuel Sendor Connections
ddgonzal Posted on: 2011/12/2 1:33
That looks as if someone added a third wire.
Normally there are two:
1. Black earth/ground wire
2. Yellow signal wire
#3 Re: Fuel Sendor Connections
Sumith Posted on: 2011/12/2 3:14
Hi DD
Ok Thanks, I have Fuel Indicator here on the dash how it works ?
thanks
regards
sumith
jpg  Fuel Indicator.JPG (53.78 KB)
10994_4ed8427e837bd.jpg 640X480 px
#4 Re: Fuel Sendor Connections
ddgonzal Posted on: 2011/12/2 6:05
Hi Sumith,
I cannot see it in the photo. Can you take a closer picture?
There is fuel gauge in the large circular gauge cluster.
#5 Re: Fuel Sendor Connections
Sumith Posted on: 2011/12/5 16:37
Hi dd
Here it is Left Side Fuel and right side Door Indicator addition to main cluster indicator.
thanks
regards
sumith
jpg  Fuel Indicator 1.JPG (60.01 KB)
10994_4edcf3ae75068.jpg 640X480 px
#6 Re: Fuel Sendor Connections
ddgonzal Posted on: 2011/12/5 20:13
That is not a gauge, but rather a warning lamp. It is a 'low fuel' warning lamp. It is possible that is what the third wire on the fuel tank sender is for.
#7 Re: Fuel Sendor Connections
Sumith Posted on: 2011/12/6 2:56
Hi DD
Thanks, that is what i also thought it is not working could be bad wiring or burned bulb,
thanks
regards
sumith
#8 Re: Fuel Sendor Connections
edp Posted on: 2011/12/7 4:01
Do you own a test light ? its for checking electrical connections - if not buy one of those along with the tuning equipment Dave suggested in the other thread. You can use it to trace wiring circuitry & everything else.
#9 Re: Fuel Sendor Connections
datsa73 Posted on: 2011/12/7 6:22
I always use an ohms meter and a a long wire with alligator clamps on each end. That way I can check a wire from one of the car to the other.
