#1 datsun 120y tai;shafts/diffs - tech help needed asap
4slips Posted on: 2012/4/6 6:15
hey guys i have 120y manual with a jap diff ( not borg warner ) i need to know if i can use a auto diff to replace it with ?
can i use an auto tailshaft in the manul box? cheers
#2 Re: datsun 120y tai;shafts/diffs - tech help needed asap
Posted on: 2012/4/6 7:59
Auto and manual h150 diff flange are same it's only tail shaft length and input flange into gear box that differ.
You might be lucky and get a 3.7 ratio
#3 Re: datsun 120y tai;shafts/diffs - tech help needed asap
4slips Posted on: 2012/4/6 14:19
Thanks mate so the diff snouts should be the same? So I should be able to just put it in? If the snouts are different can you just change the flange on the front?
#4 Re: datsun 120y tai;shafts/diffs - tech help needed asap
Posted on: 2012/4/6 22:00
The flange should be same. Measure the one you have and the one your going to buy.
