#1 common modifications
sunnyjack Posted on: 2013/7/20 15:05
Want to know the common modifcations to make my 1200 go that little bit harder
#2 Re: common modifications
Posted on: 2013/7/20 19:53
Viagra?
Common is carbs maybe cam. Xhaust too. Im being vauge as what do you wan. Torque or top end.
You may need consider brakes suspension gearbox and diff too.
#3 Re: common modifications
clyons8 Posted on: 2013/7/20 20:48
Some fairly common modifications:
Electronic ignition.
Weber 32/36 carburettor.
A14/A15 engine swap.
Oval Port Head.
Extractors.
Camshaft regrind.
#4 Re: common modifications
bakat Posted on: 2013/7/20 20:55
electric fan rather than pulley. lighten the flywheel a little bit, better clutch.
#5 Re: common modifications
D Posted on: 2013/7/21 10:06
L series
#6 Re: common modifications
bakat Posted on: 2013/7/21 10:23
hahahaha +1 for an L.
#7 Re: common modifications
warner01 Posted on: 2013/7/21 16:02
I read a post a long time ago.
I drilled holes in my chassie rails to make the car lighter.
DONT DO THIS.......
How about a a14/15 conversion....
#8 Re: common modifications
ddgonzal Posted on: 2013/7/21 19:40
Lighter means quicker accleration. Lightening holes are used by race cars.
To go harder, the most common modifaction is larger engine: A14/A14, L16/L18/L20B, or CA18DE/CA18DET.
