Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Datsun B110-B310 engines
RICLAGE
Posted on: 2002/10/18 10:32
Hello
Can anyone tell me if the A12 Engine + 4 speed Gearbox + Final Transmission Shaft can be swaped from a B110 to a B310. I have a set of these parts in mind for a very cheap price and so I need to know it. Ricardo
#2
Re: Datsun B110-B310 engines
mikko1200
Posted on: 2002/10/18 15:45
Hello.
Only the 4-speed is a straight fit. The older A12 blocks (pre-74) had distributor and engine mountings in different place than the newer engines. B110 prop shaft flange is different from B310 prop shaft flange. And lenght might be different too (not much) I hope this helps.
#3
RICLAGE
Posted on: 2002/10/18 16:54
Thank you
So the gearbox is completely compatible? But the engine fits on the mounts? Ricardo
#4
mikko1200
Posted on: 2002/10/18 18:31
Gearbox is fully compatible with Sunny 120Y gearbox. 140Y and 150Y have diffrent gearbox. If you put B110 engine into B310, you have to modify engine mounts. B210 engine will fit straight into B310.
#5
dimlight65
Posted on: 2002/10/18 20:56
Mikko, that list of cars in your signature, are those the cars you have now or all the cars you have had in the past? If it is a current list, you have me beat. If it is a list of past and present, we're about even. Either way, it's good to see that there are others as sick about these cars as I am.
#7
dimlight65
Posted on: 2002/10/21 16:38
