Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Engine rebuild sleeve rebore
leon86
Posted on: 2017/1/30 14:12
Hi all.
Im busy rebuilding engine but need some advice. Block sleeves look good no scratches or visual wear Should I rebore just for safety or hone and use stock size? Thanks in advance
#2
Re: Engine rebuild sleeve rebore
Posted on: 2017/1/30 22:11
Block sleeves look good no scratches or visual wear To determine if rebore is REQUIRED, measure the bore. Instead of visual inspection: * measure top and bottom diameter for "taper" wear * measure at 90 degrees for "out-of-round" Maximum out of round .. 0.2 mm Maximum taper ......... 0.15 mm If no rebore is required, you can refit the original pistons after a ridge and hone job If you need new pistons, consider getting oversize pistons. Going 3mm oversize will gain you 3x more power than a compression increase. See Bored And Stroked
#3
leon86
Posted on: 2017/1/31 3:01
Thank you ddgonzol for the response.
I'm changing pistons and after reading your post decided to increase 1mm ..something about 77x77 just sounds good Compression will be lowered for some snail power :)
#4
Rallytwit
Posted on: 2017/1/31 3:51
Just an FYI for the gang; A-series tend to endure monumental abuse (mostly from me) but I used to just check piston to wall clearance and if it was remotely close slap,new rings in......no hone and then almost completely ignore sound break in procedures. When my A12 wore out it had 80lbs of cranking pressure and would still pull 7200 RPMs. When I pulled the motor apart you could visibly see the wear.
Naturally this is the wrong way to do it....................but they will tolerate it. Tom You can view topic.
