FF engine in a rwd car
Would it be possible to put an engine out of a b13 sunny into a 120y
Posted on: 2004/1/30 18:22
Re: FF engine in a rwd car
From Arlington, TX, USA
There are no readily available transmissions that will bolt up to either the GA16DE or the (FWD) SR20DE engines. You could do it but you'd have to fabricate a transmission bellhousing to use a RWD transmission.
The real question is why? The GA16DE makes very little power, so that swap would really be worthless. The SR20DE is readily available in RWD form elsewhere, so that swap is pretty much worthless.
Posted on: 2004/1/31 3:54
1973 Datsun B110 Coupe (A15/5spd)
1977 Datsun 280Zed (5.0L/5spd)
