Castor rods
From Sydney
Does anybody have any "Stanza" castor rods spare, lying around? I need two ( left and right ). Im in the Sydney area.
cheers,
Benny.
Posted on: 2004/2/5 2:35
Re: Castor rods
From Sydney, Australia
Use the 1200 ones.
The difference is simply size, and a REALLY small difference in the angle. You might have to heat up the rod and bend it at the lower arm end a little, or elongating one of the holes in the lower arm might help.
I went to the big hassle of fitting the stanza ones (which are an inch or 2 longer).
Just a thought.
Posted on: 2004/2/5 4:17
Re: Castor rods
From Sydney
bump
Posted on: 2004/2/6 1:26
Re: Castor rods
From Brisbane, Australia
I use the 1200 castor rods. you don't need to bend them, just elongate the rear hole.
Posted on: 2004/2/6 1:35
