Well, I got out this weekend and worked on my car (I haven't been giving it much attention except driving it).
You might remember I bought it
last August and drove it 750 miles home. But other than
tightening up the steering gearbox, removing the engine from the trunk, adjusting timing & carb (
instructions), and converting to electronic distributor, I hadn't even changed the oil! Here's what I did this weekend:
Changed the oil. When I went to put the new filter on it, I discovered it was the wrong one. So I just put the old one back on, rationalizing that new oil is more important than a new filter. I used 10W-40 (2 qts Mobil + 1 quart Chevron -- got to use up what's already here).
Adjusted the timing. After swapping distributors, it was pinging slightly, but worse, the starter would barely turn it over. I used the marks on the distributor (
photo) to retard it two degrees. It is no longer pinging, and it starts right up without taxing the starter. Starts right up now -- it seems like -- after cranking only half an engine revolution.
Checked spark wires & #4 plug because of the cold-running problem
discussed previously. #4 wire ends were oxidized, as if it had been missing. My ohmmeter seems to be broken, so I didn't get very far. The plug looked good, a nice tan color on the inside. I wiped the exterior porcelain clean, but it didn't seem to make any difference. It runs 'good enough', so I'm not too concerned right now. I could spend $30 on new wires, but I'd rather find the problem first before buying parts. The wires look pretty good other than the oxidization.
Wired up the tachometer that's been in the car several months ... this is my 1st-gen Celica tachometer, which bolts right into the regular tacho spot.
Cleaned out the trunk. Now I can go around corners without worrying about things sliding around back there. It had a two boxes of stuff in there from when I bought it (tires chains, spare manifold and carb, flywheel, oil, fluids ,etc). I threw out 1/2 garbage can of oil-soaked newspapers and stuff from the trunk. The oil came from the spare engine (which I removed from the trunk a couple of months of ago). Ya, poor way to treat a fine automobile!
Checked the demister hoses (windshield heater vents). There was a half-dollar in the right side, which explains why that side did not defrost so well ... The good thing is that this 1200 already had the vent tubes replaced with real plastic ones, probably from a B210. The original fibre/paper Datsun 1200 ones tend to fall off occasionally.
I celebrated by driving downtown Seattle and going to the Japanese bookstore. They had the magazine
J's Tipo #133 and #132, but I missed
#127 (Sep 2003) which had a feature on the Datsun 1200 (I am bummed ...). They also had the current
Nostalgic Hero for sale, in which I counted more than a dozen Datsun 1200s in the back in 'for sale' ads (GX-5, sunny trucks, etc). It looks like a very cool magazine. The feature this month is the first GTR. It's all in Japanese, but has lots of pictures.
