Browsing this Thread:
1 Anonymous Users
Tech help |
From Canberra
Hi all, Can someone tell me what the OD (outside diameter) of the rear axle splines to suit a H165 diff centre are????? I want to build one of those phantom grip type LSD's to see if they work or not. 1200rallycar recons they work so I thought the only way to find out how well they do the job is to make one. I just need the size to allow enough clearance in the bore of the phantom grip when designing it. I could just bore a BIG hole in the centre but because I dont have much room in the plates it will be better if I keep the clearance hole to a minimum. The whole unit will be smaller than I originally thought to make everything fits inside the little H165 centre. If this type of LSD doesnt handle the pounding it's going to get then I will be forced to design a multi plate type centre. Which is a pretty big exercise so I'll try this idea first. Any help will be appreciated.
Cheers, Paul.
Posted on: 2004/3/9 1:16
