How Do i remove my steering wheel
From Sydney, Australia
i have a saas steering wheel fitted and need to replace some rubber washer to stop play in the wheel for rego, ive removed the wheel and now i am faced with a bolt with a nut inside the boss kit when i remove this nut i get stuck as i still cant remove anything else.
any ideas or help greatly appreciated
Posted on: 2004/6/5 3:56
Re: How Do i remove my steering wheel
Leave the nut on but undone slightly and pull!!!
Posted on: 2004/6/5 3:59
To do something well is so worthwhile that to die trying to do it better cannot be foolhardy. It would be a waste of life to do nothing with ones ability, for I feel that life is measured in achievement, not in years alone.... Bruce McLaren
i tried what you said who your datty but still no luck??
Is there a chance it cound be rusted on, it doesnt look like it.
Any other ideas?????
Posted on: 2004/6/5 4:15
wd40 and patience. You might have to use a bearing puller.
Don't hit it with a hammer. The 1200 collapsible column, is only held solid by 4 nylon/PVC dowels , they are about 3mm in diameter each.
Chris
Posted on: 2004/6/5 4:21
Cheers dattodude, i read what you said about the column in a post i found in the search, being a '78 will mine have the collapsible collumn or the straight stick.
I guess i'll have to go and get that WD40, what is a bearing puller????
Posted on: 2004/6/5 4:24
Posted on: 2004/6/5 4:35
Thank God for WD40
Posted on: 2004/6/5 5:13
So I take it you got it off?????
Posted on: 2004/6/5 9:05
yeah its off
Posted on: 2004/6/8 6:26
