the stock alternator is 25amp
the 200b i think is around 50
the ea comes in two versions, 75 and 85 amp
unfortunately i dont have my digi cam for 8 weeks so i cant take a pic of how i mounted mine, but it's easiest to install on a-15s
firstly there is two types of bracket, one is a very solid bracket, where the other is webbed, i remember the more solid version is better for the job
basically what i did was used the original front of the bracket to bolt directly to the front of the ea alternator, this lines the pulley up fairly accurately with the crank pulley, i then marked the bracket and cut the extra "meat" off the back of it that wasnt required by the ea alternator with a angle grinder (the bottom pivot holes on the ea alternator are closer together than on the datto versions), i then got an appropriate size drill bit and drilled right through the bracket from one hole to the other, to increase the hole and remove the thread, this allowed me to use the single bolt right through that comes on the falcon (one of the pivots on the alternator has thread in it, so a nut is not required either)
i had to muck around a bit grinding off the bracket to allow the alternator to swing fully, but this becomes obvious when you get to that stage
now the wirring, thats simple, but im gonna run to my car now to check it
ok, i undid my loow and removed all the now unnecesary wires and shortened them and all that buisness, but at the end of the day, i tossed the regulator, and connected the fat white with red tracer wire to the main terminal on the alternator, then theres is two wire from the bushes/regulator part on the alternator, one is also connected to the main ternimal of the alternator, the other connects to the thin white with red tracer wire, this is the dash warning light. thats all that needs to be hooked up.
that fat white originally went to the alternator anyway, and the thin one originally goes to the regulator
have fun, wish i could get you a pic of the mount but sorry, dad took my camera on holidays
[edit] both versions of the alernator have the same mounting and wirring
and i got my alternator for like $15 on special at a pick-a-part, a reco one is going to be around or over $150, so i just grabed a few second handies
, it's only the bushes that are gonna wear out really and they are easy to replace yourself
