Browsing this Thread:
REMOVING STEERING WHEEL???
From canberra australia
hey everyone
i have just brought an aftermarket steering wheel and boss kit but my old steering wheel wont come off??
is there a special lock nut or something that i cant see???
PLEASE HELP ITS REALLY PISSING ME OFF!
cheers frank
Posted on: 2004/10/31 2:46
Re: REMOVING STEERING WHEEL???
They are an interference-fit on the splines. There's just the one large nut.
You need a steering-wheel puller, which is a small gear-puller kind of thing. You can get one at an auto parts store.
Posted on: 2004/10/31 2:56
thanks heaps mate
ill let ya know how it goes
Posted on: 2004/10/31 3:01
Sometimes you can get it off without a puller. Don't pull on the wheel rim cause it could get damaged. But if you pound with both your fists at the same time, from behind, near the hub, it might pop off.
Posted on: 2004/10/31 3:07
From Brisbane
just make sure you put a cushion or pillow in front of u or the steering wheel when you are pulling it manually by hand.
or get a steering wheel puller cost onyl around $6 at super cheap auto or you can make one urself.
good luck
Posted on: 2004/10/31 5:20
From Melbourne, Australia
bah, buy a tool?, no way
get in there, loosen the centre nut, but dont take it right off as it will stop you from knocking yourself unconscious with the wheel when it comes off
and then pull that barstard like you've never pulled before, and hit it too if you think it will help, but i've always been able to do then by hand
just make sure that nuts there to stop it flying out at you, i've heard stories of guys knocking themselves out doing this
ask unfamilia.... he gave himself a blood nose when i was at his one day (sorry mate had to say it)
Posted on: 2004/10/31 5:35
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From penrith
i got every wheel so far off by hand (4 wheels) that is
just hit the wheel on each side really really really hard and fast to shake the spline loose and yeh it just pulls out or try pullin it from behind to u while sittin in the seat just rattle it so much ay shake that spline loose! the older the car seems to be harder tho but i got a 81 gemmy one off hurt tho, didnt use paddin on the wheel lol
Posted on: 2004/10/31 7:56
From Sydney, Australia
Just hit the wheel on each side really really really hard and fast to shake the spline loose
Never hit the steering wheel, only four 2mm plastic pins hold the steering column together. And the interference fit of the top and the bottom halves of the steering column.
I am yet to find an old 1200 steering column that hasn't been partially/totally broken due to dodgy rough tactics like this.
Go buy or make up a steering wheel puller. Otherwise soak the thread in WD40, wait a few hours, and tap it lightly, with the risk that you might need to go find another steering column, and/or steering box.
NEVER BASH A COLLAPSIBLE STEERING COLUMN!!!!
ps. I used to think this advice was all BS, but after pulling more than a dozen 1200 steering columns apart, I would no longer recommend rough tactics.
Once the plastic pins are broken, there is no way you can fix them properly.
Posted on: 2004/10/31 8:46
From Christchurch, New Zealand
I agree with the passive advice. Spray with WD40 and leave to soak. Leave the nut just on and I found the easiest way was to put my knees up behind the hub and push with those while pulling the wheel with my hands (but on the centre spoke and not on the actual wheel). Once the right angle is found the wheel should just pop off. And I tried this without the knees and thought that the knees helped get the angle right. Good Luck
Posted on: 2004/10/31 10:12
1972 Datsun 1200 Coupe
Rosso Corsa Red
14" Watanabes
Twin 1.5" SUs to go on
Extractors w/ 2" exhaust and muffler
Sony Xplod Sounds featuring Active Black Panel, 4 Channel Amp, 4 way 6x9s & 12" Sub
dattodude, what are the symptoms of the broken pins? Does it make the wheel loose, as if the bearing is bad?
Posted on: 2004/10/31 15:58
