fuel hoses
From Perth Western Australia
I removed my fuel tank as part of my upgrade, while i painted underneath, and have recently put it back in. I have had problems putting the fuel hoses back onto the tank. (These are the ones that go from the fuel filler to the tank, not the fuel lines)
are there any hints/tips/techniques i could use to get them back on?
Posted on: 2005/1/31 12:01
Re: fuel hoses
From Brisbane, Narangba
If they are hard and stiff replace them if not try some boiling water to soften them. Once to get a hose on i used a tappered bit of steal and kept pushing it into the pipe while pouring hot water which made it that fraction bigger and it went on.
Posted on: 2005/1/31 12:07
Re: fuel hoses
I'll have to try that... otherwise i'll do the other trick which should work good..
GET DAD TO DO IT FOR ME!!!
Posted on: 2005/1/31 13:41
Re: fuel hoses
From Brisbane, Australia
Use a lubricant, WD40 etc. . . Only for the hoses. . .
Posted on: 2005/1/31 22:25
Re: fuel hoses
From WA
your sump is a mobile oil can.
a drip of oil on the bung will help things immensely.
Posted on: 2005/2/1 5:18
