rear brake lock up
From Springwood NSW, Formerly Tas.
my rear right drum brake stays on once you release the pedal, i took off the cover and wobbled some stuff (after i realised it was locking) put the cover back on, and it span "freeley" until i pressed the brake, once released it was still on and couldn't move it. the shoes are thick at one end and thin at the other.
Posted on: 2005/3/3 12:05
Re: rear brake lock up
From sydney australia
this happened to me on a 1200.the brake shoe is getting caught on the backing plate.simplest fix,fit new shoes,so the shoe isnt pushed so far.
or fit a new backing plate,which means changing bearings.
Posted on: 2005/3/4 9:36
