Another Overheating Problem
From Brisbane
Hi
My car is running really hot, 60 - 70kph my temp gauge shows over 3/4 above that speed the temp gauge goes nearly on "H" top of the hot gauge
So far I checked my timing, idle, air/fuel mixture, timing belt, new thermostat with 3mm hole, swap my radiator to 323 one. I checked the radiator 1st before installing it and seems pretty good flowing really well and fins look great.
Flush the old coolant and new coolant in 323 radiator then run for few minutes for air pockets.
I can't hear any loud bearing noise for my waterpump or no leakage coming from the pump.
I checked my compression
Cylinder 1 = 172
Cylinder 3 = 170
Cylinder 4 = 165
Cylinder 2 = 168
recently I noticed blue-ish smoke on start up so probably need valve seal or rings...
No milky stuff in the radiator so far, no leaking hoses
Any suggestions or ideas?
Cheers
Posted on: 2005/3/15 1:49
Re: Another Overheating Problem
From Brisbane, Narangba
Any steam out the exhaust. Could be craked gasket or head letting the charge blow into the water.
Posted on: 2005/3/15 2:42
From Mudgee NSW Australia
Faulty-wrong Temperature sender?? My temp guage was reading nearly 100 degrees !! It ended up the wrong sender real engine temp was only 80 degrees
Posted on: 2005/3/15 2:53
If In doubt run more BOOST
From Brisbane
no steam coming out from the exhaust...
How do I check the temp of the coolant manually?
Posted on: 2005/3/15 3:33
From Brisbane Aust.
Same problem with my new sedan. Temp gauge shows between half and hot all the time. I am luck enough to work for an engineering company with meters etc. Took several reading and my water was no more than 80
Posted on: 2005/3/15 4:32
From Warburton vic
hook up a capilary temp gauge or put a thermometer it the radiator that will soon tell you what is happening.
Posted on: 2005/3/15 5:02
Are you losing water/coolant from the radiator anywhere? i.e its not just boiling over but leaking somewhere from the engine/gearbox?
You sure the radiator is flowing well? No crap in there and water galleries?
Diagnosis becoming clearer with more info!
Dave
Posted on: 2005/3/15 7:13
From Brisbane
not losing any water at all, no leaks anywhere
took it to Red Devil radiators yesterday and their 1st comment is my rad is blocked, then I told them I flushed it nicely and checked it and they double checked it and its not blocked at all its in very good condition.
They checked the water pump as well and also good.
Checked the head as well and they said theres no problem....
so Im leaning on temp sender unit being faulty
where can I get a replacement unit? or should I just install a new water temp gauge?
Posted on: 2005/3/15 22:05
From Warburton vic
Try a new sender but it could also be a gauge problem. Go to a good auto parts store & buy a capilary temp gauge or it could also be called a mechanical temp gauge & put that in. You can get them for about 30 - 40 bucks. Those types of gauge generaly read accurate
Posted on: 2005/3/15 22:25
Yeah and make sure its a right rated one, i.e. different tempuratures for different applications.. This same thing happend to me but it WAS my radiator, not saying it is yours tho...Mine had grass seeds stuck in 2 of the passage ways!
So im guessing the engine doesnt really radiate that much heat compared to normal then? Like the engine bay isnt as hot as norm?
Dave
Posted on: 2005/3/16 5:49
