Show us your rear end!
From Canberra
This is for all the guys running Stanza front struts.
What diffs are you guys using at the back to increase the rear track? Do you even bother to widen the track? Is the wider track at the back a hassle for TRX rims?
Thanx
Andrew
Posted on: 2005/3/24 0:49
Re: Show us your rear end!
From Christchurch. NZ
Cuurently I am just using the standard H165, but looking at changing to the H190 for increased track width.
Posted on: 2005/3/24 0:57
From Sydney
I run a 1200 ute H165 housing, with 20mm bolt on spacers.
The H165 housing from a 'Vanette " is 90 mm wider in track compared to the 1200 ute H165 housing. Maybe this could be an option. With TRX rims, they probably dont have sufficient backspace [120mm from memory] to tuck under the guards without flares.
Benny
Posted on: 2005/3/24 1:41
From Perth W.A
on my 120Y coupe i am looking at the corolla release of the 120Y 'borg warner" 120Y sedan diff. it is a couple inches wider and should bring the stanza front track width into balance. they should end up matching.
Posted on: 2005/3/24 2:14
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
From Brisbane, Australia
aren't you clever? wonder where you came up with that idea...
Posted on: 2005/3/24 2:47
From Okinawa, Japan
How much extra track do the stanza struts give you anyway? I was thinking of using them but my wheels already stick out far enough for some flare requirements. I don't want to go too wide and I don't want to change wheels.
Posted on: 2005/3/24 3:10
stanza struts with the local Aus Girlock brakes give about 3" extra track from what I recall
and the Aus KE55 BorgWarner diff housing is almost millimetre perfect to equalise the front and rear tracks, so you can use the same offset wheels without looking silly
Posted on: 2005/3/24 4:02
