stearing trouble
From south australia
i am trying to put the stearing back in to my 1200 i have the teath in the stearing box lined up in a central position wit the wheels in a streaght position
but every time i turn to the left it pops of the circlip that holds the shaft in to the stearing collum and the shaft is moving in and out as i turn the wheel left or right
the only thing that i can think of that is causing this is that it has 120y front struts
is there any thing that has to be changed whith thease struts any ideas what i am missing guys as this car was disasembled when i baught it i am at a bit of a loss
pleaaaasseee help me
Posted on: 2005/3/30 10:31
Re: stearing trouble
bump
Posted on: 2005/3/30 14:43
From Sydney, Australia
You've busted the "collapsible" section of the steering column.
The note says "don't hammer on wheel"... You are experiencing the symptoms of why this is recommended.
The 1200 collapsible steering column is held together by a little friction between the slip surfaces and the 2 nylon pins that are created by molten plastic when the column is made.
You'll need another column to fix this.
Posted on: 2005/3/30 14:51
i didnt hammer it
i have been through two collums already
lucky i have one more left
thanx mate
Posted on: 2005/3/30 14:58
