how do u remove gauge surround
From Northern NSW
i want to paint that bit of plastic that goes around the gauges and cd player and air control vents etc ...u know the dash plate part that faces u when u drivegoes from cd player to headlight controls
anyways i had a look at it and it seems as if there are just no screws or anything to undo
any help would be great thanks heaps
Posted on: 2005/4/7 11:47
dato ute (see avatar)
a14 blowthrough turbo motor
Import Auto Parts
For all your jap performance parts and accessories
pm for availabilty and quotes
Re: how do u remove gauge surround
From Geelong, Vic
i think you have to get it out from the back, ie take the whole dash out.
its been a while since i took mine out so i dunno
but im pretty sure that the gauges and the cigarette lighter hold it in
Posted on: 2005/4/7 13:20
From Warwick, QLD
you have to undo the teater control knobs (screws underneath) also undo the knobs off the wipers and light switches as well as remove the screws. Then you need to undo you speedo cable and theres a big round plug that attaches to the back of your instrument cluster, and any other wires attached to it. Then there should be 1 or 2 screws that screw down brackets coming off the tacho or speedo. I can't remember which ones.
But yeah thats pretty much how you do it.
Cheers
Damo
Posted on: 2005/4/7 13:24
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
