Rear Disc Brakes on B210?
From Vancouver BC Canada
Is there anyway to make the front brake assembly from a B210 work on the rear or do you have to do a more extensive swap to get discs in the rear?
76 B210 Coupe (Canadian)
Keith
Posted on: 2005/4/15 5:15
Re: Rear Disc Brakes on B210?
Not too shy to talk
From Narre Warren Vic
Good dey ey, I dont think those discs will fit over the axle hubs. If you got self serve wreckers over there , go spend half a day trying discs on that rear end and when you find a disc with the right cantre and pcd ,(fwd is a good source) grab em and some calipers with built in handbrake ,er ,bits ,take them home and fit the discs ,slide the cals over the discs to were you want them to sit, cut some mounts to suit the cals and weld them onto the dif housing. Rear bias may be a problem but a good workshop should tell you how to mod youre master cyl. Brake lines may need atention too but they're usualy cheap to get made up.
cheers Joe
Posted on: 2005/4/15 11:57
From Burbank, CA
I've been thinking about the rear disk brakes too, but upgraded front brakes would help way more for less work. A better reason to swap the rear axle would be a stronger locking diff. Rear brakes are not used as much to stop a car.
Drum brakes just arent cool, I understand.
I'll get a 200sx rear axle some day, but it's for the H190 ;)
Posted on: 2005/4/16 3:42
|||\ 81 KPB310 /|||
