Obviously if your float can crush it isnt a solid float. You need a hard foam filled float ( do rochestors have these? i dont know.) When your float has crushed, do you need to replace it? or does it expand again? How do you know the fuel bowl floods? What fuel pressure do you run?
I still stand by what I said. The pipe you installed has only provided a boost leak. For the carbie jets to supply fuel to the engine you require a lower pressure on the engine side of the jets. If you have boost pressure on both sides of the jets, you still get the vacuum effect of air passing the jets to draw out fuel like a normal carbie is designed to operate. If you put a lower pressure line into the carbie especially the fuel bowl, you create a low pressure port for any greater pressure to head to. Naturally the greater pressure will go to it and along with it, it will draw the fuel from the bowl.
Do you have a pic of this pipe you added? or even a pic of the carbie to show where you attached it?
I would love to see that flexible rubber piping when its supplying 15psi to the carbie
