CA20E O2 Sensor Wiring Help
From Brisbane
Hey everyone
my friend and I was fixing his 1200 during the long weekend, he did a CA20E swap on his 1200 sedan anyway...
the CA20E has an O2 Sensor attached to the exhaust manifold and the wire has been cut and we dont know how to wire this up?
it looks like its just a single wire... does anyone here by any chance know how to wire this sucker up?
does it go straight to the ECU? what gauge of wire should we use?
cheers
Posted on: 2005/4/25 23:18
Re: CA20E O2 Sensor Wiring Help
From Sydney, Australia
It uses a shielded wire (coax) generally. It would be "best" if you went to the wreckers and cut the wire out of another loom.
But if it's a single wire..it definitely goes straight to the ECU 02 sensor pin. Going to the wreckers with a multimeter, will give you a chance to find out which pin.
Chris
Posted on: 2005/4/26 1:39
From Brisbane
thanks for that...
now to search for a wrecked CA20E equipped car
they came in with Bluebirds, gazelles right?
Posted on: 2005/4/26 2:09
Not too shy to talk
From bundaberg qld
i think you should be looking in a pintara
Posted on: 2005/4/26 12:14
From Warwick, QLD
YEah I believe CA20E's were in Series 3 Blueys so chem them as well.
Cheers
Damo
Posted on: 2005/4/26 12:22
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From Central Vic
series three only had carby
pintara or gazzel
Posted on: 2005/4/26 16:58
From Brisbane
what year pintara? is it the boxy shape or the rounded shape?
cheers
Posted on: 2005/4/26 23:26
Both!
R31 Pintara (Like R31 skyline)
Also U12 Pintara, which has a CA20 frontwheel drive.
Some of the early (or base model) R31 Pintara's had a carby, and therefore won't have the O2 sensor.
Posted on: 2005/4/27 0:01
From Brisbane
more question...
Do we need a 1986+ CA20E model ECU for the 1986+ engine???
cos we only have the 1984 ECU and I'm guessing the 1984 engine doesnt have an O2 sensor
is it a straight swap? or do we have to do the whole harness wiring again?
Posted on: 2005/4/28 2:17
From Brisbane
does changing ECU (no o2 sensor) to the newer ECU for the same car and same engine bear in mind that the newer engine has O2 sensor and the old one doesnt
do we need to re-do the wiring of the entire car again?
we are stuck please advise and help
thanks
Posted on: 2005/4/29 1:10
