tacho wire.... which one is it?
From Melbourne, Australia
having installed the delco, and not using the stock coil loom anymore as it all works through the computer i have no tacho anymore
there is a wire "tacho signal" from the camira coil, i just have no idea which wire in the 1200 loom to connect it to, and this doesnt seemed to be displayed in the manual????
cheers fellas
Posted on: 2005/5/6 9:22
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: tacho wire.... which one is it?
From Central Vic
the signal wire for the tach is power to the coil from the ignition
it goes past the tacho its an induction system
the wire goes through the back of the tacho no brake to the coil
Posted on: 2005/5/9 12:03
ah k cool that makes sense, but, i guess that means i have no tacho then....
unless i run the power to the coil from the computer, past the tacho (however i need to do that)
hmmm, dunno if i wanna do that, maybe i need to go for an aftermarket tacho
Posted on: 2005/5/10 6:06
1200 Coupe Rallycar
From Sydney, Australia
With aftermarket ECUs and 1200 tachos, it's almost a fixed requirement.
I worked out a way with my standard CA18 loom to get it working, but I'm yet to fix it with the Autronic. Wasted spark throws an extra variable into the equation.
But now that I think about it..it should still work... Even though it's firing 2 coils at a time, the positive line feeding all of the coils, has the same signals on it. Just that both are firing at once... I'll wire this up when I get home.. Thanks for making me think about my problem some more.
Cheers.
Posted on: 2005/5/10 7:07
