I just got the SR powered beast on the road (temporarily) and started finding some bugs in the brakes.
If you've followed along my SR buildup you'd see that I've installed front and rear disk brakes and a new master cylinder from a 1983 280ZX (Fairlady Z). Something funny is going on with the rear brakes now that I've gotten to drive it around some.
Basically what's happening is every time I step on the brakes, it's building up and not releasing pressure in the rear brakes. It takes a few pumps to get it there, but eventually the rear brakes get totally locked up. Just to be able to move the car I loosened the rear brake line on top of the brake bias assembly and sure enough brake fluid came squirting out under pressure.
The master cylinder is brand new as are all the brakes and rotors (calipers are used). The E-brake isn't even connected at this point either, but it still did it with it both connected and disconnected.
The master cylinder/brake pedal IS in fact returning all the way out when the brake pedal is released, so I don't see why it's holding pressure in those rear brakes. Could it be something internally in the master cylinder? Perhaps because it's new, one or some of the seals or valves are sticking that allows the pressure to bleed off when you release the brake pedal?
It had this problem when I first put the brakes on and bled them through, then a few days later when I came back the binding rear brakes seemed to mysteriously disappear....which I'm thinking the pressure buildiup finally slowly released itself over a few days, but then when I drove it around for a while it didn't do it at all......until today when I drove it.
Does anybody have any ideas as to what the problem could be? It's got to be something with the master cylinder, but I know that it's going through it's full travel.
I'm hoping it'll fix itself over a few days and more driving but I doubt that'll happen. I do have another spare used 280ZX master cylinder to try out if you guys think this new one is no good, I just don't want to have to take it all out again...it's so messy!
Let me know what you guys think the problem is! Thanks!
