what do i need 2 run 2 32/36 Webers on a a14 eng
From Melbourne, Australia
i want to fit 2 32/36 Webers what will i need 2 do
Posted on: 2005/5/26 11:19
When the going gets tough the Datsun keeps going😋
Re: what do i need 2 run 2 32/36 Webers on a a14 eng
From sutho shire
u need a adapter plate from local spare parts shop and a few basic hand tools
really easy swap
Posted on: 2005/5/26 11:56
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
From Adelaide, Australia
Twin Downdraught Webers! need to do Alot. Any good at tigwelding? Goodluck. My old mans RS2000 had twin downdraughts, could mate one of those manifolds up to a a-series manifold. Go with some twin DCOEs a-lot less hassle.
Sean
Posted on: 2005/5/26 12:10
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Christchurch, New Zealand
I think DVLDAT was thinking of a single application.
Here is a thread on this matter and it may be easier than thought with a little creativity.
Twin Downdraught
As said, it seems to benefit high rev applications.
Posted on: 2005/5/26 12:48
1972 Datsun 1200 Coupe
Rosso Corsa Red
14" Watanabes
Twin 1.5" SUs to go on
Extractors w/ 2" exhaust and muffler
Sony Xplod Sounds featuring Active Black Panel, 4 Channel Amp, 4 way 6x9s & 12" Sub
From Perth Austarlia
For starters...get hold of 2 32/36 webers
Posted on: 2005/5/26 16:44
you would need a twin carby manifold for a start, there are occasionally twina12 manifolds for the stock carby on ebay, you could then use two adaptors for the 32/36 and bolt them on, the throttle and accellerator cable would be the difficult part and then trying not to overfuel the whole thing on the stock 32/36jets.
i would just use the one unless there are craxy mods on this a series you have.
Posted on: 2005/5/27 0:30
i have 2 32/36 Webers
Posted on: 2005/5/27 11:53
