are these diffs the same in the 1200 series
From sydney, australia
I was wondering if the diff from a 1200 coupe which is leaf spring has the same fittings an mounts as the 1200 ute diff.
I was getting a diff made up an the guys have the specs for the uts diff but not a coupe.
I suspect they are the same. If someone can tell me beforre i buy one it would be very helpful.
cheers
Posted on: 2005/7/5 7:36
Re: are these diffs the same in the 1200 series
From NSW
If you're putting a 1200 ute diff into a Coupe yes it is the same width and the mounting points to the leaf springs are the same. The Coupe tailshaft will however not bolt up to a ute diff. You'll need the ute tailshaft and also the u-bolts from the ute diff, or suitable replacements. Not sure about the steel brake lines...I made my own.
Cheers. Dan
Posted on: 2005/7/5 8:07
From sydney
I have a ute diff drum to drum for sale for $300 if you are interested.
Posted on: 2005/7/5 8:29
From Sydney
Hey galahazard...
What diff are you using for the build? Is it being made by a workshop or a mate? If a workshop which one? Only ask cause i'm looking into getting a diff made...
cheers
Matt
Posted on: 2005/7/5 11:21
Hey guys,
thanks for the feeedback.
DATT-MATT: Im getting the diff made up by Diff technics in Kograh, Sydney.
Its a fully recote diff, 7 1/2 inch borg-warner which is strong enough for my purposes. Im only doin a stock CA18 conversion. LSD, 28 spline axles, Disk brakes, all mountings in right spot for ~ $2500. Not including fitting but its piss easy.
I think is a reasonable price considering what you get.
To do that with another diff its roughly ~$2500 anyway an i couldn't be bothered mucking around.
sidedraught: Na dude, no thanks.
Posted on: 2005/7/5 12:17
