leaks.. can u tell me where they coming from? **pics**
From penrith
from wat i can see its the timing case ( for timing chain, front of block) and maybe sump gasket?
im pulling the motor out in about 2 weeks wont sell it nore more, gotta do the clutch its slipping.. so ill do these then
should i take the motor out to do the clutch? is this a way it can be dun i no u can take the box out to do it, take out both or need i do just motor?
Posted on: 2005/7/12 9:18
Re: leaks.. can u tell me where they coming from? **pics**
From Burbank, CA
is all that oil dripping down from the valve cover or where the head and the bottom end connect? pictures are bad.
Posted on: 2005/7/12 20:36
|||\ 81 KPB310 /|||
From Adelaide, South Australia
I can't see any from that photo just clean off the oil and see where it starts from when it starts to leak.
Posted on: 2005/7/12 21:12
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
From penrith
rocker cover is sweet, ill wipe off the sump 2mos and the whole motor from wat i can see and fire her up, 100% sure its teh timing case, and i hope its not the sump haha
Posted on: 2005/7/13 8:25
