L20B heads opinions??
Quite a regular
From hilo,hi
I heard alot of different opinions but i want to hear your guys opinion...which head will be best base head for a wicked motor...I have o/s stainless valves...1mm.... waiting to be put on a head.but i want to make sure before i work-out a worthless head, and i could have gone with a better option..
1. I have a w58 head with the exaust liners taken out and ported majorly..will that suit a worked motor???yes but will a different head be better?has anyone done that??
or i could go with the 210,or the u67..i know the u67 is very common..but possibly could my worked w58 be worth to use?
Specs: plans:L20B w/dual 45s ,headers,radical cam,forged pistons,nitrous plumbed......lots of trips***
I just would like your guys opinion so i could finish my dream mobile..thanks
Posted on: 2005/7/21 4:58
Re: L20B heads opinions??
Quite a regular
From hilo,hi
has any one used a w58 head like the one i have,w/exaust liners out and ported??
how was it...or could any one guess how it will perform...??open chamber....
Posted on: 2005/7/22 0:09
From Melbourne Vic
U67 are open chamber heads. go with the old CCC theory for power - compression cam carbs. the U67 have big ports but open chambers, whereas the A87 head (L18) has peanut (closed) chambers but smaller ports. i think there is a closed chamber head from an L20 called a V91 but they are quite rare.
Posted on: 2005/7/22 4:27
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From Canberra
in that case: For sale, v91 head, good condition $150
v91 aint rare and aint closed-chamber, all blueys had 'em I think
Posted on: 2005/7/22 9:48
From Bridgetown, Barbados. W.I
So A Standard W53 Head ......would give better performance on a L20b Compared to the standard U67 head???
Posted on: 2005/7/22 15:34
Life's better SIDEWAYS!!
Quite a regular
From hilo,hi
o.k but......my ? is will my w58 head w/exaust liners out and ported heavily do the deed.. will it out performe other heads..there is no exact answer...just opinions
Posted on: 2005/7/23 0:00
Quite a regular
From hilo,hi
i just want to know which head will be good to spend time on....and will be well worth it.i already got the worked w58 but i'm just curious before i put it on...and go trough all that and get ####...it would be good if someone already has done that and could give feed back....,,,,,
Posted on: 2005/7/23 0:08
From Central Vic
with the cost involved mainly being in the work you would do to the head i would be looking at the cleanest head that will give you a suitable compression
If your happy with running pump fuel and with price of fuel id be trying to get away with 95 octane
id probably chose a series two bluebird head they will be the easyest to find in good condition and they appear to have good port castings from what ive seen
If you want the comp your looking for the closed chamber L18 head
Posted on: 2005/7/23 10:23
