what is the 1st thing you would do ???
From Brisbane Australia
Hi Guys, A very simple question.
If you bought a 5 speed gearbox what is the very first thing you would check when it arrived ??
This is a no brainer , but I need everyones answer.
thanks Ade
Posted on: 2005/8/14 12:32
Re: what is the 1st thing you would do ???
From Warwick, QLD
whether it's really a 5speed
Posted on: 2005/8/14 12:49
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From Springwood NSW, Formerly Tas.
yeah i'd do that 2, we were lookin at a corolla 5spd and it turned out to be a rooted 4spd so yeah
Posted on: 2005/8/14 13:29
1978 120y Coupe.
Thanks guys, that is the answer I knew I would get but I need alot more people to post there comment.
I will tell the full story in a few days
cheers Ade
Posted on: 2005/8/14 13:49
Quite a regular
From Brisbane, QLD, AUST
to see if it works hehe?
Posted on: 2005/8/14 14:06
From Sydney
I pulled a gearbox from a trashed 1200, stored it and didnt realize it was a 5 speed until a friend came over and saw the smooth case and commented.. That gearbox is now in the 1200..
Yes, I would make a mental note before buying a gearbox to check the number of gears, as i have been caught out before!!
Posted on: 2005/8/14 14:14
From Tamworth , NSW
make sure it wasnt like , a gemini box.
Posted on: 2005/8/14 14:21
From bendigo victoria
make sure its a dato 5 speed and if its a rally box or overdrive box
Posted on: 2005/8/14 14:25
I would put it into each gear and spin the input shalf and see that each gear turns the output shalf.
Posted on: 2005/8/14 14:33
To do something well is so worthwhile that to die trying to do it better cannot be foolhardy. It would be a waste of life to do nothing with ones ability, for I feel that life is measured in achievement, not in years alone.... Bruce McLaren
From Castro Valley,CA USA
I would do the same paying special attention to the relative speed and direction of the output shaft in 5th and Rev.
Posted on: 2005/8/14 20:32
