disc brakes all round for 1200 ute
From brisbane
hey guys i was just wondering if any of u know wat kind of brake rotors from wat i can use on my 1200 ute?
Posted on: 2005/8/30 7:36
Re: disc brakes all round for 1200 ute
From sydney
On the front ,1200coupe,120y, on the original struts.
or you could put in stanza struts and disks, and then the list goes on and on.
Bluebird disks on the rear fit onto the ute diff.
Posted on: 2005/8/30 7:40
From penrith
any particular type of bluebird? i heard wagon ? and also heard u needed an "adapter plate"??
Posted on: 2005/8/31 8:59
From sydney australia
bluebird trx or lx rear discs will work,but they need 14 inch wheels as a minimum.
Posted on: 2005/8/31 12:41
hmm,
im putting 200b struts and discs in my ute front end. i would also like to put a disc brake rear end in. But i think im just gunna put a H190 under the back. my dad has the machines to shorten them.
Does it matter what H190 i use? i want it to be a disc brake model.
the reason i choose the H190 is because of the alloy LSD available to them. and coz its a datsun diff.
but that brings me to my next question, i have previously read about setting up the brake booster? i have a stanza booster, 120y booster and a 200b booster. the 200b has rear end disc brakes. ( im pretty sure it does ne way?)
and that brings me to my last question. where do i get a H190 from?
I will swap a 1200 ute diff for a H190 in GOOD condition. i dont want a winey diff. and i will also swap another 1200 ute diff for the LSD centre.
sorry bout the long post. back on topic ai?
jono.
Posted on: 2005/8/31 14:59
78 model datsun 1200 ute. A15 twin webbers, dogleg 5speed.
Jk Rubicon unlimited, 58 CJ3B Willys
From brisbane
ill be running 15 or 16 inch rims so that shouldnt be a drama
Posted on: 2005/9/1 3:10
jono,the best place to get a h190 that wont be whiny is probably a s12 gazelle.these come in 3.7:1 & 3.89:1 ratios,manual being the 3.7:1.
or the z24 powered urvans had 4.1:1 h190's.all of these are 4 stud,so no change of stud pattern.
Posted on: 2005/9/1 5:38
From brisbane
cant u use the original diff of the 1200 ute? thats wat i was gona do
Posted on: 2005/9/3 6:08
