120y Springs
Quite a regular
From Gore, NZ
Are the B210 and B310 front springs interchangable and are one of them longer than the other?
Posted on: 2005/9/15 5:01
Re: 120y Springs
From Vancouver BC Canada
I put some b310 springs in my b210 struts today and the car is riding high.
Maybe I overlooked something as I thought the springs were the same length, strength, and diameter.
anyone done this swap?
(b310 springs into a 120y)
Posted on: 2006/1/2 11:09
If at first you don't succeed, lower your standards.
Keith (Mac-Datty)
Re: 120y Springs
If you thought that they were the same, then why swap them?
Posted on: 2006/1/2 11:14
Love your Datsun.
Treat it well.
Re: 120y Springs
They weren't rusty....
Posted on: 2006/1/2 20:26
Keith (Mac-Datty)
Re: 120y Springs
From sydney australia
id say the sunny springs are longer,as the sunny struts are the longest of the lot.so get out the wire brush & some cheap spray paint, flat black or otherwise & recondition them.
Posted on: 2006/1/3 2:22
Re: 120y Springs
The tech section here says that the b310 springs are actually shorter than b210 springs.
Posted on: 2006/1/3 3:18
Keith (Mac-Datty)
Re: 120y Springs
From Geelong, Vic
from memory the sunny springs are half way between stanza and 120y, or somewhere near there
sunny ones are definatally longer
Posted on: 2006/1/3 6:22
Re: 120y Springs
according to the tech section..
http://datsun1200.com/modules/nsectio ... p?op=viewarticle&artid=68
b210 front coil spring
free length = 375mm / 388mm (w/ac)
b310 front coil spring
free length = 381mm / 375mm (A12A)
this making me confused.. :(
as i thinking getting 240z spring into my b310,
cause i read that B310 and B210 strut is the same,
and someone is using 240z spring with cutting out one coil for their B210 strut..
Posted on: 2006/9/9 11:37
Re: 120y Springs
Not too shy to talk
From Malaysia
i've the solution...check it out..u know where right?
Posted on: 2006/9/12 5:22
Re: 120y Springs
From Brisbane Australia
yes mate I have swapped them after I had them very nicely powder coated and the phucking car looked like it was running up hill so out they came and two coils removed.
ask tappet how it rides now
cheers ade
Posted on: 2006/9/12 8:42
