main bearings
Hi again,
Further to the last post, when I tighten the bearing caps the crank locks up ( I put them back in the right order...same shells etc).
Maybe I'm overtightening them? I set them to 50lb foot.
Help !
Posted on: 2005/10/8 14:09
Re: main bearings
From Perth
even if you think you have them in the right order you might have them in backwards undo them turn them 180' and then try again.
Posted on: 2005/10/8 14:28
Re: main bearings
Roger that...will do.
Posted on: 2005/10/8 14:29
