oil pressure
From NSW South Coast
Can anyone tell me what oil pressure I should have. ( A series )
Olboy
Posted on: 2005/11/8 7:52
Re: oil pressure
at idle mine is usually 30psi but in the warmer weather drops to a bout 25psi (i dont like it at 25 as the idle gets a bit rough). At crusie it is about 60-65 and at hi revs is about 70-80psi (same as when cold).
this is of my mechanical guage so who really knows..... i just hope its accurate.
Posted on: 2005/11/8 22:01
Re: oil pressure
From Warburton vic
Mine sits between 40-60psi. But i use a smaller oil filter then standard.
Posted on: 2005/11/8 22:29
Re: oil pressure
whats smaller that can replace a z145a or z154a... i always forget which type it is on the 120y style a12....
Posted on: 2005/11/9 10:20
Re: oil pressure
From Springwood NSW, Formerly Tas.
its 145, got one yesterday
Posted on: 2005/11/9 13:22
1978 120y Coupe.
Re: oil pressure
From Okinawa, Japan
Are big oil filters bad? The one I use is big compared to what I've seen on most A series but I'm getting the same oil pressures... I thought bigger would be better but never really looked into it or gave it much thought.
Posted on: 2005/11/9 13:40
Re: oil pressure
From Castro Valley,CA USA
Is the oil pressure port before or after the filter? I've never noticed much of a change when changing filter sizes. I usually use a Fram ph8a (ford) or the longer 977a.
My oil presure is 58-59psi at 4k
Posted on: 2005/11/9 19:25
Re: oil pressure
From Warburton vic
I use Z386. They are toyota 4 cylinder. The genuine toyota oil filters have better paper in them & is folded in a way that they have more paper. They have a better 1 way valve also. I put one un a claged 3y 4 cylinder i had in my hilux & the oil light went off almost straight away. They are a better filter than any ryco or genuine nissan. I have seen proof at the toyota training centre.
Coops
Posted on: 2005/11/10 0:00
Re: oil pressure
so the z386 is a direct screw on replacement on the a12, a14 and a15 style a series s it?
might have to try this one...
I do find the toyota filers pretty good on my corolla, hacksawed the first one in 1/2 after running the car in to check for metal flakes..... they do have a lot of folds in them...
Posted on: 2005/11/10 22:31
