webber jetting
From Alabama, U.S.A.
Alright guys I have had my webber on my stock A14 for about 2 weeks now and she boggs until you lift the throttle a little , then you feel it coming on then. I'm thinking the jetting is too big what would be the best jetting range for a stock A14 ? This is what I have in right now (32/36 DGV)
primarymain jet-135
secondary main jet-140
Posted on: 2005/12/3 22:34
Re: webber jetting
From sydney australia
the haynes weber book says the jetting for a 32/36 weber on a 1599 cc cortina engine is 1.35 primary/1.50 secondary fuel jet,1.70 primary/1.40 secondary air correction,with a 0.55 primary idle & a 0.45 secondary idle jet. i've tried this setup in my 120y with an a15,& it's still slightly rich in the main,so i've gone back to a 1.27 main,& it seems much better(only did it yesterday afternoon & haven't really driven the car).there are all sorts of combinations listed in this book,but the above set up makes the most sense to me.lots of set ups seem to have a larger main than secondary fuel jet & balances it out with the air corrections.hope this helps.
Posted on: 2005/12/4 7:08
Re: webber jetting
I am trying to figure this out cause I have never tuned on a webber that much . I'm used to tunning on a HOLLEY. I took apart 3 different webbers comparing mains & air jets. They all have diff. type setups in them. do you need to change the hole jetting all at one or can you do only one jett at a time?
Posted on: 2005/12/4 18:01
Re: webber jetting
From Vancouver BC Canada
You CAN change them all at once, but its probably best to figure out which one you NEED to change and do it one at a time.
Oh and keep a log of what you have and what you change, or you will get confused and frustrated.
Posted on: 2005/12/5 7:12
If at first you don't succeed, lower your standards.
Keith (Mac-Datty)
Re: webber jetting
Thanx guys , I don't have many jett sizes to choose from right now , but workin on it.
Posted on: 2005/12/7 2:00
Re: webber jetting
Posted on: 2005/12/7 5:00
Keith (Mac-Datty)
Re: webber jetting
From Adelaide, Australia
I can also vouch for this alfa guy off of ebay, got all my jets for my dellortos and chokes etc. really good, fast turnaround etc.
Posted on: 2005/12/7 8:40
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
