12a into 1200 ute
From Bendigo, Victoria, Australia.
does anyone know if there is a kit to mount a 12a rotary into a 1200 ute?
Posted on: 2005/12/7 4:41
Re: 12a into 1200 ute
From victor harbor
the way i did it was i installed a taller gearbox tunnel, then sat the 12a in with a series 1 rx7 5 speed (because of shifter position, needs to be a forward shift otherwise the shifter hits the handbrake) and made up custom engine and gearbox crossmembers. the engine mounts were mounted on plates which were welded to the chassis. i also used a rx7 radiator and oil cooler and i modified the radiator support to fit it. car drove good and stayed cool, real fun to drive. it's a worthwhile conversion because the 1200 motor standard is dead and you can pick up whole rx7 fairly cheap.
Posted on: 2005/12/7 7:59
