a15
From Penrith NSW
i need some help in the carby dept what is a good set up for a a15 cant seem to get hold of any webers and weber manifolds are even harder to find or are they??,Su carbs would also be nice ,once again hard to find
Please help me !!!
Posted on: 2006/1/4 10:28
Re: a15
From Sydney.au
-ive got a stock N13 carby setup with an auto choke, jetted for an a15.. 4 sale if u want it
-single weber manifolds for oval port v hard to find
-twin manifolds and webers are everywhere + on ebay
-twin su's seem too tricky to setup.. unless you can buy some tuned. flat tops r better ive heard. (hitachi ones) use heat shielding!
-nice quad motorcycle carbys hard to find
-efi + everything too expensive
then again someone on this site might be able to sell you webers or su's.. ?
edit : duh forgot 32/36 down draft weber! theyre everywhere too.
Posted on: 2006/1/4 10:42
Re: a15
From sydney
I have to disagree about the twin SUs, I have had a few sets of the factory GX setups and compared to Webers they are a snack to set up and tune.
Posted on: 2006/1/4 10:47
Re: a15
The best multiple carb setup that I ever drove was my factory 1200 GX induction. It was a snack to set up, & once the carbs were balanced & adjusted for the right idle mix, I did not really need to touch them for the next fifteen years.
Note, these are the factory Hitachi's, & not the similar looking SU's.
These are my first choice for a mild street A series engine.
Posted on: 2006/1/4 15:26
Love your Datsun.
Treat it well.
Re: a15
From Penrith NSW
hi, thanks for the tips ,how much do you want for the stocky setup.
Posted on: 2006/1/4 21:06
Re: a15
From campbelltown (sydney) australia
ive got a set of two 45 mm dellorto carbs with manifold linkages fully rejetted just need to sort out the jetting and a few other things and theyll be good. give us a pm if ur interested.
Posted on: 2006/1/5 6:36
* caution, sunglasses must be worn to view my ca18det *
