a/c in 1200 ute???
From NSW
hi all, just wondering if anone here has tryed putting an a/c system in a 1200 ute. i am running a ca18det and im not sure if i have the room for the unit?!! i was thinking about getting a unit that can run off the 12v???? any ideas??
cheers guys n gals..
Posted on: 2006/1/11 10:20
Re: a/c in 1200 ute???
From Bendigo, Victoria, Australia.
there was a thread about a/c not that long ago
anyway, back to the original topic.
as for room, the pump/compressor (part driven by belt) shood fit in alrite, depends on how big ur interooler is - therfore how much room infront of the radiator remains - as to wether or not u'll get the radiator looking thing in...
then you have to run steel tubes thru the firewall (cutting firewall means eng. cert.) and have a switch to activate the unit somewhere in the cabin.
have a click around google, it knows everything, or have a look about 6 posts up (just disregard that arguement)
if worst comes to worst and u cant get info, just have a go at fitting it in urself. u can always take it out agen.
best of luck
Ronald
Posted on: 2006/1/11 23:14
Ronald
That's news
Maybe you should only give advice on topics you are educated in and havent only just read on google.
Posted on: 2006/1/12 5:58
From WA
electric AC compressors
you'll need a 100amp alternator to run it though.
cutting the firewall for hoses has nothing to do with engineer's certs. as long as it is sealed witha rubber grommet or similar to stop chafing and seal the cabin.
Posted on: 2006/1/12 6:14
thanks for ur 2 cents phunk.
Posted on: 2006/1/12 8:43
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
Glad I could help.
We all come here to learn.
Education is a wonderful thing wouldn't you agree.
Posted on: 2006/1/12 11:46
