Browsing this Thread:
1 Anonymous Users
Is this a starter prob |
From Durban, South Africa
Hey guys, my van wont start. Battery is strong. the starter wont swing at all, not even click. tried t giv it a few knocks, then it just gives a "click" wen u turn the key. If i kick start the van it starts no prob. Is it my starter thats faulty or the solenoid?
Posted on: 2006/2/20 8:40
Re: Is this a starter prob |
From Bendigo, Victoria, Australia.
id say the solenoid. replace it, then if it still wont start have a look at the terminals on the starter, sometimes they come loose over time. other than that, check all wiring, and check the fuse. a mulitmetre or test light are handy tools for this.
Posted on: 2006/2/20 9:38
"Like a Rolling Stone" Bob Dylan
New Daily: <<<<Now For Sale. 1972 B110, 13" Bathurst mags, airbrus
Thanx i'l giv it a try
Posted on: 2006/2/20 10:01
From Sydney, Australia
yeah clicks mean worn out or dirty solenoid. This can be caused also by a faulty ignition switch or wiring.
Pull the high tension lead from the coil that goes to the distributor to stop the engine starting. Use a wire from the starter spade terminal, and when you are away from the motor, push the jumper wire to the positive terminal of the battery...it should crank careful of too much sparks..
If it works every time, then it's the wiring or ignition switch. If it still clicks..it's the solenoid.
Posted on: 2006/2/20 12:08
'71 Green 1200 Sedan CA18DET Project 99.98% complete '71 White 1200 Sedan 20,000mi + A14T (twin 40DCOE 30/70 cam, extractors) Website: http://www.shoeys.com
If you eventually find that you do need to pull the starter, then don't just replace/ repair the solenoid, but pull the whole thing down for cleaning & inspection, then repair as necessary. You will kick yourself if you replace the solenoid, only to discover that the brushes wear out a few weeks later.
Posted on: 2006/2/20 14:04
Love your Datsun. Treat it well.
yeah kno wat u mean. if u get someting done, do the whole package at once.
Thanx guys, i'l only have a chance too look into in this wkend. Let url kno wat was wrong.
Posted on: 2006/2/21 10:10
