Manifold Flange Cad Files??
From Melbourne, Australia
Hey, just wondering if anyone has cad files they have used to make flanges for inlet and exhaust manifolds (oval port A14).
Would make it easier for me to get them laser cut (rather than having to draw them up).
If you do, let me know. Most formats ok, but l guess autocad is preferred by most laser cutters.
Posted on: 2006/3/8 21:39
Re: Manifold Flange Cad Files??
From Wellington New Zealand
Can't you scan a plot into CAD? ie draw around a gasket scan it and add it as a file?
Posted on: 2006/3/9 0:11
1200 coupe 1400 GX 5 speed
1200 coupe LHD peripheral port 12A rotary.
1200 ute
Sunny 310 SGX.
Quite a regular
From Southside of Brisbane
That is how I would do it scan the gasket in with some measurements on it so you can scale the picture to the correct size and then you can trace around the outside, would only take 5 or ten minutes to do it. I do it all the time with old house plans etc that are in imperial dimensions
Posted on: 2006/3/9 1:39
Lead
Thanks guys....l have no problem doing it myself. Just wondering if someone already has them, and they know fit properly ?????
Posted on: 2006/3/9 8:47
From sacramento california
i have a 3d cad file of a manifold gasket shape if you need it i can send it to you
Posted on: 2006/3/12 12:23
From Adelaide, SA
Casper, can you send it to me? Cheers!
Email button below \/
Posted on: 2006/3/13 0:28
i sent it to you.
Posted on: 2006/3/13 1:06
i wouldnt mind it also please.... tickfordcortina@yahoo.com
thanks mate!
Posted on: 2006/3/13 1:40
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
I know this might be a stupid question but what program opens ems files?
I have a couple of CAD style programs none can open it.
Posted on: 2006/3/13 1:59
i didn't use auto cad or autodesk inventor because i couldn't find my run disks. i used this program i downloaded in less than 5min from E- machine shop
]it is a pretty easy program. the company will even build the part if you want.
Posted on: 2006/3/13 5:13
