Wrong Exhaust manifold gastet
From Wagga Wagga nsw australia
i just ordered in a new head gasket kit for my a12 , and there all pretty much the same except for the exhaust manifold gaskets. My manifold has oval shaped gasket compared to the new gasket which is circular and doest fit properly. has this happened to anyone else??
(my ute is 1200 1980 if that helps)
Posted on: 2006/4/25 2:42
Re: Wrong Exhaust manifold gastet
Quite a regular
From Mira Loma Ca. USA
You are talking about intake ports? Chances are you have an A14 head, which is oval port, but you should be able to trim the gasket to fit your intake ports. If you feel it to be too thin use an A14 mani gasket. probably available by itself...
Posted on: 2006/4/25 7:58
1965 Datsun Fairlady 1500-A14 powered!
5 Speed All GX parts with twin Dellorto 40's
10:1 compression. 1976 B210 stock smogger with "dogleg" 5 speed and a ton of suspension work (coilovers, camber plates, etc. etc. etc.)
its deffinatly to thin i have to re-order
Posted on: 2006/4/25 8:15
The round inlet port head is correct for an A12, while the heads with oval ports were used on A14/15's as well as the high performance A12GX.
If your gasket has round inlet ports, then it would be correct for the car. If your head has oval inlet ports, then it, or even the whole engine, has been changed.
Check the engine number for the engine model. It will likely have either A12, A14, or A15 as a prefix.
Posted on: 2006/4/25 10:21
Love your Datsun.
Treat it well.
From Portugal
Hi, i
Posted on: 2006/5/17 12:25
From Philadelphia, PA
Call NISMO @ 1-888-449-5131 ask for Shay. Tell him Ken Webb refered you.
http://www.nismoparts.com/catalog/sm
Posted on: 2006/5/19 2:29
From Portugal
Thank's!!!
Posted on: 2006/5/19 23:40
