FS: '71 1200 ute (pics)
From Canberra
1971 model 1200 ute for sale.
-Has worked a14, ported polished head, matchported inlets, double valve springs, balanced bottom end, twin 40mm webers, extractors and 1 3/4" exhaust.
-smooth case 4-spd gearbox.
-120Y struts with new king springs
-new ball joints/bushes and stuff in front end
-1.5" lowering blocks in rear
-13x5.5" mags (not the mags pictured)
-retrimmed bluebird? seats
-pumped rear guards
Body isnt perfect, but its fairly straight, will need fibreglassing or cut and weld in foot wells.
front carb leaks fuel (havnt opened it to see whats wrong) Needs a few weather seals etc.
needs carpet/door trims
Needs a new tailshaft, I'm looking to get one for it and when I do the price will go up accordingly. Also the right rear drum is locking up, I just took the drum off to roll it around. Once again I'll look to fix it and ad it to the price, so if you want to do it yourself the ute is cheaper.
Would make a good project or a neat daily driver with a little work. No rego/rwc.
$2000 pick up only from canberra
edit: phone 0422 620 053
Posted on: 2006/6/3 11:00
Re: FS: '71 1200 ute (pics)
From Canberra
bump
Posted on: 2006/6/4 8:02
hey tyrie,
i think ive got a few spare ute tailshafts $100 let me know if ur keen and ill check
thanks
Posted on: 2006/6/4 10:33
