diffs and struts
From Sydney
can you use s12 gazzelle diffs or struts in a 1200 if so i may have 2 sets of struts and 2 diffs ???
Posted on: 2006/6/8 15:20
Re: diffs and struts
From Melbourne Vic
you can sort of use the struts. it's like an R31 conversion, you'd need to remove the spring percha and weld on a stanza one as the spring diameter is massive. you may also need to machine a spacer to fill the larger hole at the bottom of the strut that bolts to the steering arm. the diff i'm mot sure but they have an IRS model and a live axle model.
Posted on: 2006/6/9 3:29
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From Sydney
anyone else know about using a gazzelle diff????
or front struts??
Posted on: 2006/6/19 3:19
From Sydney
anyone?
Posted on: 2006/7/1 17:47
From Gold Coast Australia
Im not entirely sure but if they are similar to the R31 (diff) like LAGWAGON says, they are good for the disk brake rear end and keeping the same stud pattern.
I am going to be using a shortend R31 (skyline) diff in my SR20DET sunny.
Posted on: 2006/7/1 19:18
SR20DET Sunny for sale, click me for details
