Flat slide motorbike carbs?
From Adelaide
Im looking for some Info on using flat slide motorbike carbs for my track car. Im using a twin cam 1600cc engine what sort of size should I be using for a quad carbie set up?
Posted on: 2006/6/21 2:59
Jap Addict
Re: Flat slide motorbike carbs?
From Bris-Vegas
Depending on your setup & what rpm / HP you're running......
I'd start with some 42mm Mikuni Flatsides.
These can delivery enough fuel to keep a 1100cc sportsbike screaming @ 13000 rpm, so fuel delivery shouldn't be a problem.
However bear in mind, your standad header tune won't suit these too well - I'd suggest custom tuned length headers & or a re-jet to make the most of these.
They're a bitch to tune too - Make sure you cost some equalizing vacuum gauges into the overall cost.
Posted on: 2006/6/21 4:23
CA18DET '74 1200 ute project
From Adelaide
Thanks a lot for your help. First sensible answer ive heard all week :P
Posted on: 2006/6/21 7:00
Jap Addict
From Bris-Vegas
No worries - Based on info I learned in a previous life as a motorbike nut
Posted on: 2006/6/21 8:40
