wanted A12 timing cover
From Toowoomba, Aus
If any one has an A12 timing cover they can afford to get rid of I'm most certainly in need. Cheers
Posted on: 2006/6/27 12:39
Re: wanted A12 timing cover
i don't have one but i'm sure theres a few floating around on the site ............ could all depend on where you are located ??
people from all over the big wide world on this site, so if you put a location into your profile you should get all the help you're looking for
Posted on: 2006/6/27 12:42
What model of A12?
The A12 that was used in Datsun 1200's had a single timing pointer in it & the various timing marks were on the front pulley. At some point the design changed & a single mark was placed on the pulley. The new casting had the different timing marks on it, so there are two types.
Either can be used on any of the A series engines, but you need the matching pulley if you use the early one.
Posted on: 2006/6/27 13:10
Love your Datsun.
Treat it well.
From Toowoomba, Aus
It's a 75 model 120y engine with single crank pulley. The timing cover has multiple timing marks on it. Cheers
Posted on: 2006/6/27 13:16
This is the most common type, so someone should have what you're after.
Posted on: 2006/6/27 13:17
Love your Datsun.
Treat it well.
From SE Melbourne
Where's Toowoomba? In Vic? Sounds like it would be in QLD.
Posted on: 2006/6/27 15:17
Mildman, Datsunless
From Bendigo, Victoria, Australia.
Mildman wrote:
Where's Toowoomba?
You're right, Queensland Mildman.
Posted on: 2006/6/28 7:41
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
