High compression head onto stock bottom end
From Bunbury Western Australia
I am about to receive my high compression high port high flowed oval port head, 4000-7500rpm cam, twin weber manifold and Mikuni carbs.
I was wondering what my chances are of installing the combo onto my stock 120Y bottom end without rebuilding it first as I am a few dollars short at the moment?
I won't be revving it past 6000RPM until it is rebuilt but I am anxious to get some more power!
Posted on: 2006/6/30 14:17
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
Re: High compression head onto stock bottom end
From Brisbane, Narangba
Depends on the condition of your motor to some extent(if its reasonably fresh go for it).
If your only going to rev it to 6000rpm i wouldnt bother, you'll find the power the cam makes there isnt all that great. Also old engines dont like higher rpms than their used to. A slight ridge forms over years of the same low speed rpms and all of a sudden you increase the revs the pistons will rise up ever so slighty more ramming the top ring into the ridge. No need to explain what happens there.
Posted on: 2006/6/30 14:32
i say go for it you alreay know the bottom ends going to need a rebuild
Posted on: 2006/6/30 14:34
what if I were to leave the cam for now and just install the head and mikuni's?
Posted on: 2006/6/30 14:35
it'll still work but you'll be getting no where near enough lift or duration of the valves and may find it hard to tune due to the amount of fuel going in.
still worth a try .....
Posted on: 2006/6/30 15:08
From Adelaide, South Australia
What do you mean by high comp ?
12-13 ?
Posted on: 2006/6/30 16:44
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
Also to change the cam you realise you'll have to pull the whole engine out. Just for the amount of time spent i say wait a month till you have the money then go for it.
Posted on: 2006/6/30 17:50
12.5:1 compresion ratio with flat top's
I agree I should wait a month for the extra cash to do the job right, I am just anxious to get it done right now!
Posted on: 2006/6/30 19:31
From brisbane
What fuel will you be running for that sort of compression?
Posted on: 2006/6/30 19:39
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
98 octane fuel and bluebird series 2 distributor with 17 degrees advance
Posted on: 2006/6/30 20:05
