what the difference in diffs for 1000's
From Adelaide, Australia
can any 1 tell me the difference between a datsun 1000 ute diff and all other 1000 diffs? r the axels different lengths? ect..
also what is my best option for a better diff in my 1000 ute? i belive they come out with a h145 centre
Posted on: 2006/7/24 7:42
Re: what the difference in diffs for 1000's
The only difference between a Datsun 1000 ute differential & any other Datsun 1000 differential is the ratio.
These all have an alloy carrier & are the H145 type. The Datsun 1200 passenger models used an iron diff carrier, H145 differential in 3.9 to 1 ratio
The 1000 Ute & Van used a 4.375 to 1 ratio as standard while the Sedans & Coupe used a 4.11 to 1 ratio.
There was an optional 4.625 to 1 ratio for the Van & Ute as well.
The axle shafts are the same for all.
What do you mean by a "better" differential? Do you want a stronger one, or a higher ratio one, or both, or,.....[other]?
Posted on: 2006/7/24 10:47
Love your Datsun.
Treat it well.
Posted on: 2006/7/24 12:48
Posted on: 2006/7/24 12:50
Posted on: 2006/7/24 12:53
stronger! I like the 4.1 ratio better so I wanted to try keep it. But I gather with a a14gx motor I recon I'm goNa blow it heaps
Posted on: 2006/7/24 12:55
Did you fit the diff i gave you mat?
Posted on: 2006/7/24 12:56
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Posted on: 2006/7/24 13:03
MattoRX7 wrote: [many times]
You can fit the H150 differential into your ute axle housing if you use a 2mm spacer & a second gasket, but the lowest ratio available in Australia is 3.9 to 1 with a 3.7 to 1 as the only other available choice in this version of differential.
You could go to the larger H165 rear axle assembly, but you will need to get one from something like a series 1 or 2 Bluebird wagon & narrow it.
The 1200 ute rear axle assembly is about 2-1/2" wider than the 1000 & this is just enough to stuff up your wheel & tyre clearance, but the axles are too short to successfully re-spline if you have one of these & narrow it down. Better to use the cheaper & more readily available Bluebird one if narrowing is on the agenda.
The H145 will hold up behind an A14 if you 'drive' it, even in a spirrited or sporting style, but will fail in short order if you just plain 'abuse' it, so,.... just what is your driving style?
Posted on: 2006/7/24 13:16
Love your Datsun.
Treat it well.
From what i saw on saturday night, straight line speed and burnouts!!
Go the 1k
Actually, it was my first time in a 1000 ute, i enjoyed it very much!
Posted on: 2006/7/24 13:27
IPRA Build
(1) 2 3 »
