what engine's bolt into a 120y
Hi, Does anybody know what other Datsun engines will bolt sraight in to a 120y. Its got a 1200 in it now, so im looking for something bigger that will bolt in?
Cheers
Posted on: 2006/7/25 0:58
Re: what engine's bolt into a 120y
From southern sydney "the shire"
an A14 or an A15
Posted on: 2006/7/25 1:01
You don't mention which country you are in so it's not clear just which version of the '120Y' you have. The B210 [1974 to '77] or the B310 [1978 to about '82]?
Engines that will bolt straight into your car include.......................
A12 [1974 onward] 1171cc
A12A, 1237cc
A13 [long stroke '74 B210 version] 1289cc
A13 [short stroke B310 version] 1270cc
A14 1397cc
A15 1488cc
Basicly, any Datsun A series engine that has the distributor mounted near No. 3 cylinder.
A series engines up to 1973 [1000's & 1200's] had a forward mounted distributors & different engine mount positions, & while they can be made to fit easily enough, they will not "bolt straight in"
Posted on: 2006/7/25 1:13
Love your Datsun.
Treat it well.
Thanks for that info, I am in Australia by the way. So If installing an A15, would the flywheel from my current engine bolt onto the A15? Also would the exhaust have to be modified?
Cheers
Ben
Posted on: 2006/7/25 2:05
From Melbourne, Aus
L series motors bolt into 120y's as well.
180B crossmember bolts up (from memory) and then take your pick of an L series
Posted on: 2006/7/25 2:26
Cheers
Ben
You might want to include some basic location information in your profile to avoid any confusion in the future.
If you are going to use your original gearbox, then use your original flywheel. The original 120Y gearbox was not used behind the larger engines but will fit & work well behind one anyway as long as you don't abuse it. Treat it with respect & it will last for many years, but if you practice your burnout technique with it, the service life will be less.
Posted on: 2006/7/25 3:08
Love your Datsun.
Treat it well.
From Townsville, Qld
Also, don't practice flat-shifting with them either . Dam peer pressure
Posted on: 2006/7/25 9:48
L series motors bolt into 120y's as well.180B crossmember bolts up (from memory) and then take your pick of an L series
will the L series gear box fit in the tunnel without any mods to it?
Posted on: 2006/7/25 9:56
From Melbourne, Aus
if you have an auto tunnel it will fit no worries.
The stanza 5spd fits in a manual tunnel snuggly, not sure about any others.
Posted on: 2006/7/25 11:04
Thanks for that info.
I have heard of ppl installing electric ignition and removing the "points" set up on a 1200, has any1 done this and whats involved in this, form which engine do you get the set up from.
Cheers
Posted on: 2006/7/25 11:29
