Feasability
From Townsville, Qld
I have the opportunity to get parts of a SR powered 180SX and I was thinking about the struts. Does anyone know if they could be used in a 120y? modding struts not an issue to me by the way but I would like to know
and I've searched through the tech section already
Posted on: 2006/7/27 10:29
Re: Feasability
From Adelaide, Australia
Im pretty sure 180sx doesnt have a steering arm as such, its a stub axle that bolts to the strut, so your problem would be with trying to get the lower control arms of the 180sx bolted up to the crossmember.
Also can the 120y radius rod be used or the 180sx radius rod modified to suit the 120y body??
Arent 180sx only steel single piston calipers anyway?
Id say its too hard.
What engine are you trying to stop anyway?
Dont say stock a12.
Posted on: 2006/7/27 10:39
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: Feasability
I wont . It's a demon (in the bad way - some sort of short circuit?) A12 that I'm going to replace with my A15 for Townsville and related motorsport stuff
edit: oh, and it was stock when it died in the a$%e!
Posted on: 2006/7/27 10:48
